Crucial M4 128gb on SATA 2
6 May 2009
Just ran a few tests and got the following on my Gigabyte EP45-DS3P motherboard. ACHI mode
Does all this look normal?
Machine certainly seems a lot faster. Bootracer shows total time to desktop is 18 seconds (12 seconds time to logon, 6 seconds from logon to desktop)
odd i get fair bit faster speed on s p35 chipset board, i dont think your running ahci mode or your not running the latest intel ahci drivers. (if your running ahci i doubt your even using intel drivers#)
I turned AHCI on in bios and also turned on 'SATA Port 0-3 Native mode' When it was disabled there was a few random stalls and I had to close Office 2010 from task manager, then it would not uninstall. Also my Xonar Essence soundcard drivers stalled and i had to reboot.
I formatted and re-installed with Native mode enabled
(1:45 into this video)
Can the intel ahci drivers be installed as the current stage i am with my os (everything installed) or do they need installing just after install?
Thanks
Is it one of these 2 from here - http://downloadcenter.intel.com/Sea...roductProduct=Intel®+Rapid+Storage+Technology
Intel® Rapid Storage Technology F6 Driver Diskettes
Intel® Rapid Storage Technology F6 driver diskettes v10.8.0.1003 - used to preinstall RAID drivers (F6 during Windows* setup).
OS: Windows Server 2003 *, Windows Server 2008 *, W....More Windows Server 2003 *, Windows Server 2008 *, Windows 7 (32-bit)*, Windows 7 (64-bit)*, Windows Vista 32*, Windows Vista 64*, Windows XP Home Edition*, Windows XP Media Center Edition*, Windows XP Professional x64 Edition*, Windows XP Professional*>
11/11/2011
10.8.0.1003
Latest
Drivers
This driver supports RAID 5 & 10 on specific desktop platforms; supports RAID 0, 1, AHCI & Matrix RAID on specific desktop and mobile platforms.
11/11/2011
10.8.0.1003
Latest
Drivers
Perhaps you'd be so kind as to explain in which benchmarks you get "a fair bit faster speed".
Not that I'm doubting you...
I installed the 10.​8.​0.​1003 drivers and got pretty much the same.
Just thought id try the AS SSD test on my velociraptor. Its taken over an hour and the score is Read - 11, Write 11. Total score 28! nice
Do you think it would be worth me investing £30 in a SATA3 pci (or pcie?) card?
