Its a AMD Gaming Evolved title so the 3D may work better under AMDs way atm.
True but it also lists this
- Works with AMD Eyefinity 3D 3-screen mode.
- Works with NVIDIA NVISION2 Stereoscopic 3D
That is not the kind of blur you think, that slight blur is when the bad guys are around. Whole scene gets a slight blur when they turn up. When no bad guys are about it is crystal sharp.
Yes it does, but that does not mean perfectly.
It means that nvidia won't release a 3D driver for it unless remedy sort out the shadow and lighting issues whilst using 3D. The text is also very hard to read with 3D enabled if you use subtitles.
What is your GPU? I've got a ATI 5000 series in my laptop with 1GB memory and I'm downloading from steam right now...
I suspect it will be fine on my GPU I can normally push most games to 1080 some at 1600 x 900 with the odd few having to go to 1280 x 720 only BF3 and Metro 2033 so far...
Is this actually any good? Reluctant to buy it after how they screwed us in the first place.
i played this on the xbork, yrs ago, but may have a trip down memory lane![]()
quit playing after like 15 mins.....the blur when enemy's are around is ****ing annoying
