Final spec check + Diagrams.
2 Feb 2007
Belfast
Right guys, finger is hovering over the buy button. Here is my list:
- EK-Supreme HF - Acetal + EN (Nickel)
- XSPC EX240 240mm Dual Fan Radiator
- EK Water Blocks EK-DCP 4.0 Pump
- EK Water Blocks EK-Bay Res
- 7/16" ID (5/8" OD) Masterkleer PVC Tubing Clear - 3.3 Metre Pack
- EK-PSC Compression (ID 7/16", OD 5/8") - G1/4 Black (8)
- Mayhem Pre-Mix X1 UV Blood Red - 1Ltr
- Phobya ATX Bridging Plug (24 Pin)
And here is the diagram of how I would like to install it:
So, does this look good to go?
Thanks :D
Thats a lovely diagram :)
I'm not sure if your going to achieve some of those angles though without the tubing kinking.
How did you make that diagram?
It's excellent!
The order and layout looks good to me, but you may need slightly larger radiuses to stop kinking.
It's excellent!
Made the diag with photoshop, most of the sizes are pretty accurate :)
Would you suggest getting 1/2" tubing instead? I saw that you can't put 2 1/2" compression fittings side by side on the HF though :/
Just realised they only have 2 compression fittings left.. darn, theres allways 1 thing in my list out of stock no matter where I look!
Mind end up having to go for barbs.
Do barbs look crap with rotary extentions?
Edit: They have 1/2" compression fittings in stock, i heard they may not fit side by side on the HF but some people say they will. Anyone know for sure? It would be the EK compression fittings.
Hey guys, what do you think about this layout instead?
Basically ditching the bay res and getting a DCP 4.0 Combo res solution.
Opinions?
http://lavadesignstudio.co.uk/misc/layout2.png[IMG]
Opinions?[/QUOTE]
Personally, i'd keep the bay res as they look amazing, but if you're happy with the tube one, then this is a good idea :)
RE compressoins, ask in the CS section of the forums for an ETA :)
Ah, im not actually getting my stuff from OCuK unfortunatley mate :(
Too many items out of stock at the mo. I've found a place that can ship me compression fittings via cheap post method tho which is handy :)
Trust me dude I would order from OCuK in a heart beat but they fail @ stock control!
For W/C gear anyway :p
XSPC EX240 120mm Radiator - Black - Out of Stock
EK DCP 4.0 Pump (12v) - Out of Stock
EK Reservoir Combo DCP 4.0 - Out of Stock
Phobya Nano-G 12 PWM - Out of Stock
Mayhems X1 UV Red - Out of Stock
EK PSC Compression Fitting 7/16 - 4 left
I'm also confused at how they can have 10+ V8 Watercooling Kit's in stock when they use 3 of the components above that are out of stock..? :confused:
Yea sure mate, just tell me what components you want and il make you one up :)
Thanks mate, there speks -
Case - CM Storm Trooper
CPU Block - XSPC RayStorm CPU WaterBlock
Radiator - XSPC EX240 120mm Radiator - Black :D
Pump, reservoir combo - XSPCX2O 750 Dual 5.25” Bay Reservoir Pump
Set-up similar like yours, only pump with reservoir goes to top 5.25 bay.
Many thanks in advance.
I'm more preferable to a tube res, held directly below the radiator and then going through into the pump. The 250 res for example.
It's all personal preference though.
