After lurking on this forum I thought I would give something back, and put these setting up to help beginners have a easy start in over clocking with the Gigabyte Z68AP-D3.
This is specifically for the Gigabyte Z68AP-D3). Its based on the setup overclockers sell their bundles with and was partly pulled from another thread (I would give credit if I could remember which one!):
I have highlighted the memory tweaks in blue, so don't worry about those till you have it running stable at 4.4Ghz. You should know the memory setting are based on 1600Mhz DDR3 RAM so don't bother tweaking the memory setting if you have 1333Mhz Ram installed.
To get into the bios screen press the "delete" key when the bios screen shows on restarting the computer.
4Ghz set-up (should run on auto settings for most people)
M/B Intelligent Tweaker
Advanced Frequency Settings - type in 40 - press "enter"
Now press F10 and press "y" then enter.
4.4 Ghz set-up
Advanced Frequency Settings - 44x
CPU Ratio - 44x
Advanced CPU Core Features - Press Enter
Internal CPU PLL Overvoltage - Enabled
Real Time Ratio Change in O/S - Enabled
Intel Turbo boost tech - Auto
Turbo power limit (watts) - set to 150
Core current limits (Amps) - set to 150
Intel Turbo boost tech - Disabled
Press Esc
System Memory Multiplier - 16.00
Press Esc
Advanced Memory Settings - Press Enter
Performance Enhance - Standard
set the next line down to quick
Channel A - Press Enter
9-9-9-28 - then command rate 2
Press Esc
Advanced Voltage Settings - Press Enter
Load-line Calibration - Enabled
Dynamic Vcore - +0.050v
Dram Voltage - 1560v
4.4 Ghz set-up
CPU Ratio - 44x
Press Esc
Press Esc
Press Esc
. As well as the good clocking of this board its pretty much amazing, it may not have the looks of others but performance and value for money is pretty amazing in my books.
.. I can even leave "PERFORMANCE ENHANCE" in the memory settings on "STANDARD" or "TURBO" and still be stable..QPI/VTT voltages of 1.050V(standard) to as high as 1.200V can definitely influence your stability RAM wise.
