- 14 Jun 2004
- Newcastle U/T
Just a few Q's before I run the cables.
I have faceplates/wallboxes and keystones, assuming I just follow the color coding on the keystones?
The ones I have are labelled A/B, I'm assuming you just wire up A one side and B the other?
I have faceplates that hold 4 keystones and was thinking of running 4 cables to each room, 8 to the sitting room beside TV. I have a patch panel ready also and a small switch. Is there any point in running 8 to beside the TV or if I connected a hub/switch here also would 4 runs be enough?
Also what cables do I need from the faceplates? Straight or crossover?
Also any tips/pointers before running it all?
I have a cable tester ready and Will be testing each cable when punched.
I'm hoping a reel will be enough if not will order another, was only £35 or so.
LSOH purple sleeved stuff. should be fine yeah?
