Headphone/Speakers Help?
9 Jan 2012
So I have a pair of Sony headphones that I use when the rest of the house goes to bed and I use the speakers through my monitor through the day. The headphone jack on my Antec 300 doesn't work no matter how much I make sure the front panel headers are plugged in etc. So therefore I have to awkwardly reach around the back of my system a couple of times every day and then find the cable that has fallen down to the floor. What I was wandering if by any chance whether any of you SoundCity folks know anyway I could make this problem easier for myself. Maybe have both plugged in and use software or something, as you may guess I'm clueless at the sound side of PC's. Any help would be greatly appreciated. Cheers,
Ross.
Do you not get any sound or is it very distorted from the front plugs? There's a fault in the Antec 300 case that is fixable. There are video tutorials on how to fix it if you look.
did you do this? common problem if your front panel audio plug isnt hd(jack sensing)
go to asus website and download/install latest realtek sound drivers,click the yellow folder in screenshot above and tick/untick the front panel jack detection box untill you hear sound from front headphone socket
No sound whatsoever. I think I may have damaged the connectors while installing as I felt like I pulled something a little too hard. I am getting a 600T in mid March, but it's just annoying as I use my PC for a good 4+ hours a day.
Nope haven't touched the Realtek or any sound drivers.
you need to install those above ^^ the drivers windows installs,the microsoft ones wont have the option to disable front panel jack detection hence why your not hearing any sound
