Really?... Logical answer... Go ask a Doctor?
kd
Don't know about you , but I always try to exhaust any other possibility before wasting a doctors time with something that could've been sorted over the counter.
~Clee
~Clee
just clippers on the sides and back.
ironicly i dont touch the middle and thats where the spots come and go. grrr lol.
but if you go to the doctor you get the same over the counter stuff but free on prescription![]()
Iirc,this can be caused by using clippers and how the cutting action effects folicles & regrowth.
Housemate at uni had this problem. He changed from clippers to a razor and it cleared up.
So either let it grow and go for an epic comb over, have it cut with scissors not clippers or shave it with a razor.
It might cost you more especially if like most people you have to pay for a prescription.![]()
take a job up as a door supervisor?![]()
I believe in taking care of myself and a balanced diet and rigorous exercise routine. In the morning if my face is a little puffy I'll put on an ice pack while doing stomach crunches. I can do 1000 now. After I remove the ice pack I use a deep pore cleanser lotion. In the shower I use a water activated gel cleanser, then a honey almond body scrub, and on the face an exfoliating gel scrub. Then I apply an herb-mint facial mask which I leave on for 10 minutes while I prepare the rest of my routine. I always use an after shave lotion with little or no alcohol, because alcohol dries your face out and makes you look older. Then moisturizer, then an anti-aging eye balm followed by a final moisturizing protective lotion
