Out of interest, does The Witcher 2 benefit from higher levels of vram, or does ubersampling require other higher specs to be considered to get a playable frame rate?
(above post has been corrected) but the rest is maxed, sorry about that  mate but I've not fired it up in a long time so I forgot about that.
, I only bought it due to the zero DRM policy and never played it at the time because it used to run terible on my Q6600.But quite why AMD have put 3GB on their new cards is just a marketing gimmic imo and surely inflates the price of the cards unnecessarily.
1.5 GB Cards here, SLI at 2560x 1440 - can't say I have ever experienced slowdowns or slide-shows EVER since I started playing BF3 (although I don't use MSAA normally, I can also turn on 2xMSAA quite happily).
@random guy
right, so you aren't playing at max settings then!
Come on now, what are max settings for you? Every slider turned all the way to the top?
I think you need to be a bit flexible here, because if all my settings are at Ultra and I can add 2xMSAA to get decent playable framerates across all MP experiences, then I think it hardly matters does it?
In context, the OP is discussing 1080p and I am talking about 2560x1440, so your comment is not exactly relevant.
