New system build since about 400BC......?
18 Dec 2004
NE England
Hey all,
Looking at buying a completely new system for the first time since I got my current system. To put it in perspective how long it's been, my sys at the moment is:
X1950 Pro 512mb
2GB DDR2
E6600 Core2Duo
At the time, this was a reasonably decent machine......!
I'm budgeting at the moment no more than £500 - this was including OS, but I might be able to get this cheaper through student friends.
I'll need a new motherboard, GPU, CPU and RAM. This is pretty much for Battlefield 3, so I'm guessing I'll need 4GB RAM. Don't need a hard drive or peripherals. Will my PSU be compatible with the new stuff? If so, it should be up for the job, although can't remember it's wattage off the top of my head.
Cheers people :)
What's your PSU?
Battlefield & Skyrim weren't the graphics killing beasts that we were led to believe, so no need for dual 580GTX setups just yet.
MoNkeE is running 1680*1050 btw.
The ones you have including DVD drive are SATA?
No idea without you saying what it is, open the case and see if theres a sticker on the side saying make+model.
Really? It was £70 when I bought it and meant to be a fairly decent PSU. It's also been working fine since January 2007 xD
Theres a members club - http://forums.overclockers.co.uk/showthread.php?t=17694588
I will just leave this here,
YOUR BASKET
1 x Intel Core i3-2120 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail £99.98
1 x OcUK HD 6850 OC 1024MB GDDR5 PCI-Express Graphics Card £89.99
1 x Gigabyte Z68AP-D3 Intel Z68 (Socket 1155) DDR3 Motherboard REV 1 £78.98
1 x OCZ ZS Series 550W '80 Plus Bronze' Power Supply £46.98
1 x Cooler Master Elite 430 Windowed Case - Black £39.98
1 x Crucial Ballistix Sport 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (BLS2CP4G3D1609DS1S00CEU) £37.99
Total : £408.01 (includes shipping : £11.75).
And you got some money left over to buy an OS or if you can get being a student for cheap then you can change a part or two.
That's great stulid, thanks :) left over to splash out on a new mouse and all!
Anyone else able to recommend anything comparable?
In all fairness the later Hiper PSUs such as the Type-M series weren't as bad as the earlier ones, but I think you'd still be better off with something new.
Sorry mate, that completely slipped my mind. I was thinking it when posting though xD
Worth putting extra t'wards a CPU and not the GPU?
I was actually recommended to get an nVidia 560, would this be a bad idea......?
If you get a GTX 560
Make sure you get the "Ti" Version.
YOUR BASKET
1 x OcUK GeForce GTX 560Ti 1024MB GDDR5 PCI-Express Graphics Card £159.95
1 x XFX Pro 550W Core Edition '80 Plus Bronze' Power Supply £59.99
1 x Kingston HyperX Blu 8GB (2x4GB) DDR3 PC3-10666C9 1333MHz Dual Channel Kit (KHX1333C9D3B1K2/8G) £39.95
Total : £450.85 (includes shipping : £10.00).
