SSD installed - still getting 5.9 WEI
20 Feb 2012
Hi everyone,
I recently installed a Kingston sv200s37a 64GB for Windows 7 & most used apps, while the overall speed of the system has increased I am still getting 5.9 for primary hard disk?
To optimise, I have:
Checked AHCI is enabled in BIOS
Run the test with the other drive not connected
Installed Intel Rapid Storage Technology driver
Disabled System Restore
Disabled drive indexing
Disabled the page file
Disabled Hibernation
Disabled prefetching in the registry
Disabled Windows write caching
Disabled the SuperFetch and Windows Search services
Disabled ClearPageFileAtShutdown and LargeSystemCache
Adjust power settings
Fresh Windows 7 install
Can anyone help? :confused:
I really would not worry about WEI, it really is the most pointless test.
Run something like AS SSD bench if you want to check the performance of the drive
Have you tried running the test again? Sorry if you have but it's not the most obvious thing that you need to actually click on the button (bottom right iirc) to run the test, it doesn't automatically update.
My M4 was showing at 5.9, I clicked to update it and it jumped to 7.9.
Yea, I've run the test several times :mad:
you did set to ahci in the bios? and did the reg tweak beforehand? if in ide you will get poor speeds
It's definitely set to AHCI, not sure where you mean by the reg tweak? :confused:
Try setting the power plan to performance
*sorry missed the part where you said you done that already
http://www.attotech.com/products/product.php?sku=Disk_Benchmark
download and run it to benchmark your ssd
heres my corsair gt 60gb figures
im set to balanced power profile in windows too so should work fine for you
upload to www.tinypic.com copy/paste the forum url here
use windows snipping tool to capture screen/in accessories
EDIT whats the drives rated read/write figures?
have you installed intel rst drivers from asus website?
heres specs of that ssd,speeds look about right imo
Specifications
Product Description
Kingston SSDNow V200 - solid state drive - 64 GB
Sequential read / write
up to 260MB/s (read) / up to 100MB/s (write)
upto 260 read which they are round about and 100mb write which they are
