- 2 Jan 2012
- UK.
If you look around rather than refering to only Anandtech and only on the Chase Bench, you will see in actual environment the performance is higher on the GTX480 at 1920 res and below; most of of those BFBC2 results of Anandtech are on 2560 res with 4xAA...so the lack of VRAM cripple the GTX480; and the 6970 is faster than the GTX480 is faster at 1680 res because of no AA used.
Either way, 6970 still cost around £80-£100 more.
I wonder if DX11.1 will be as succesful and useful as DX 10.1 was.![]()
Im not sure why your comparing the GTX 480 to the HD 6XXX series, you do know that the 7XXX series is out already?
You say that 28nm, DX 11.1, PCI-E 3.0 etc mean nothing.. Of course they mean something. being on 28nm process means less heat/power use. Better overclocking capabilitys. DX 11.1 means better support for future games. PCI-E 3.0 means a possible 5% performance on PCI-E 3.0 boards. You can't just say that it means nothing,it's all progress. Not to mention more memory on equivilant cards...
Im sure the majority would prefer a cooler running, better overclocking, newer feature set GPU, with more memory. i.e HD 7XXX or soon Kepler GTX 6XX
For those that are looking for a card with extreme power use, less memory, lots of heat and noise, less features than there is the GTX 480...
Im not sure why you would want to go backwards?
Like I say though, each to there own mate. take it easy![]()
I myself however would not have brought one if I wasn't going to water cool it.
Again it is with only average fps, no minimum frame rate. Have a look at the 1920 res 4xAA result here:I did have a look around but the AnandTech comparison displays the results more succinctly.
The HD 6970 also comes out slightly ahead in the Guru3D review:
Radeon HD 6950 & 6970 review
Even in BFBC2 @ 1920x1200 with 8xAA.
All of that ^
Most of this "new" stuff is just a bottle of snake oil.
DX11.1? FFS, they haven't even used DX10.1 properly yet
DX10 could do tessellation, yet it was never hyped or "sold".
PCIE 3.0? how many times, man. Nothing has maxed out the bandwidth of PCIE 2.0 yet for crying out loud, so you get about 3% over 2.0
And does any one have any concrete proof yet that existing DX11 cards can't run DX11.1? I would stick my neck out and say they can. DX10 cards ran DX10.1 when it was introduced.
And I will also vouch for the overclocking prowess of the 480. I can't see it being very different to the 470 and that went straight to 755mhz with linked shaders without batting an eyelid. The guy I sold mine to go it to 790 linked shaders without any voltage. I told him to stop there, as I wouldn't help him if he blew it up. I think he saw sense.
http://www.bit-tech.net/hardware/graphics/2010/12/15/ati-radeon-hd-6970-review/9
You won't get a 6970 with warranty for anywhere near £185
I would take a HD 7XXX or HD 6950/70 or GTX 560 Ti/570 over a GTX 480 anyday. Kepler is coming soon aswell, £200 could be spent on a newer card is what im trying to say.
I have mentioned in number of topics...AMD cards simply don't work well with the Frostbite/Frostbite2 engine when it comes to MSAA performance. And it is not specific set of circumstances...you simply won't be able to find result of 6970 with higher minimum frame rate than GTX480 at 1920 res 4xAA on BFBC2.And again you're moving away from your initial generalised statement and going into a specific set of circumstances.
And looking at your link, and based on the criteria you're now adopting, the GTX 480 is slower than the GTX 570 when you said it was faster.
The bottom line is @ £185 the 480 is a fantastic bargain to be had. If I wasn't skint I would realy consider buying 2 of them for SLI.
Also DX10.1 was non existent.
And I have said GTX570 is clocked higher than GTX480. Clock for clock it is no faster than the GTX480, but with consideration on the extra vram on the GTX480 and both cards having similar max core frequency on overclocking, the GTX480 is faster and will deliver smoother gameplay in that sense, since it is basically just a GTX570 with more vram, but with the disadvantage of higher power consumption and more heat that's all.
Also, the GTX480 is actually faster than the 6970/GTX570.
All 3 look pretty close together to me
I can't think of anything else, but didn't Clear Sky utilize 10.1?
Yep, I just googled it and there was a later patch which enabled 10.1
Depreciation of £7 in one year for a graphics card isnt bad at all!![]()
