- 19 Feb 2007
- Northampton
Im about to click buy on a new HDD and was wondering how much of a 1TB drive is actually useable, 900GB or so ?
Hi Jay, are those the capacities reported by windows?
This is probably down to the difference between GB/TB (which disk manufacturers use) and GiB/TiB (which windows uses but then incorrectly calls 'GB' just to confuse everyone). A 1TB drive is 10^12 bytes, and 1TiB is 2^40 bytes, so 1 TB works out to be 931GiB. If you're seeing more than that then your disks are either bigger than 1TB and/or the capacity is being reported in GB not GiB.
I've got both external and internal 1TB drives, one shows up at 956GB and the other is 973GB, and my internal 2TB is at 1838GB, so as you can see, there is no way to tell as data loss is random, you can buy 2 drives, exactly the same and I highly doubt they'd have the exact same capacity
