No its definitely not. Not on this forum, and not commonly anywhere in the world. I wont even bother pointing out why not or giving you the correct definition on this one, because I know you are too stubborn to accept it.
There are a whole range of Creation Theories, some are scientific, some are religious, some are philosophical, some of the adherents are Theists, some are not.
One such Creation Theory is Theistic Evolution, where the concept is that God created the Material Universe and Evolution is a natural process within that material Universe, I have yet to come across anyone in this thread who commonly refers to Creationists who defines Creationism in this way...
Unless you are suggesting that Evolution explains the creation of the Universe?
I will remember next time that when you mention Creationism or Creationist that you believe they accept Evolution as they are Theistic Evolutionists, or Evolutionary Creationists....
I know what the real definition is, supported globally and academically in any such discussion on creationism, but I was asking you for yours because you never use real definitions of anything in your arguments.
Under the real definition of Creationism, just about every single Christian, and perhaps even Muslims judging by Muza's post would be classified as a Creationist.
Creationism is also not just limited to Christian belief, anyone of any religion can hold creationist beliefs.
You don't know half as much as you think you do. You have a very narrow and blinkered view of many things and for some reason cannot seem to understand the nuances and meanings attributed by context....it's a very black and white approach that means you lack the ability to be objective. Instead you get defensive and your hubris won't allow you to consider any point of view other than what you think you know to be true...even when it is demonstrably not........in this tegard you are the same as our friends Kedge and Cosmogenesis...only they limited their stubbonous to a single subject in the main....
I did not say it was limited to Christianity, neither did I state the academic definition, which would take up half the page and include various definitions across several religions, namely the Abrahamic ones and to a lesser extent Hinduism, Hinduism can also hold that the Gods did not Create the Universe as Brahman is a pantheist concept rather than a typically anthropomorphic God as in the Abrahamic Religions....again it would take half the night to explain fully and has no particular relevance to the thread or the context in which I used the term Creationist....
(remember that all three Abrahamic religions share the same source material in regard to their various interpretations of Genesis and therefore can be properly refered to as Biblical)
I gave the most common use of the term both generally and on this forum....as well you know. Now you can be obtuse and argumentative if you wish, try to feel superior if you wish, it will not change that fact that it was a perfectly acceptable use of the word and that not all theists can be regarded as Creationists.....For example, Jainists believe in Deities, but they don't believe they created the Universe, or that they are Creators themselves....
