There are a few things you should check and do, including getting and using the right driver for your particular chipset you're going to plug the drive into.
OCZ have an SSD guide that is available from their product pages and forums. I created a checklist from that of the things that were relevant to my installation and then followed it.
It was worth doing, as an end-user you use them just like any other drive, but for the installation and configuration there is more to it than for a mechanical drive, and it takes a little time but once you spend an hour getting that done it stays done and then you can forget about it all.
really helpful guide!
Is there any problems or is this normal?
