- 13 Apr 2010
- Sunny Sussex
there is a reason warranty direct want £1400 per year for a warranty
You'd you get another?
This thread is hilarious. The down side of the internet, people read stuff and take it as fact no matter the source![]()
Yes they should start up almost as fast when hot, although a can of seafoam or bg44k can cure that if the cause is just carbon build up.
Iv had two 231s and loved both of them, got rid of the first as i wanted to fit my bike in, then got a second car so bought another, then i wrote that one off.
There not very fast for what they are though, if i returned to rotary cars it would only be an rx7.
Im keen on owning an rx8 at some point, although I understand they arent without problems, it is a great drivers car and after all it is RWD (Right Wheel Drive).![]()
On the reliability front, how bad is it? I recall that the advice on an RX7 is to budget £1000+ for a rotor rebuild at some point. Has the RX8 improved at all being more modern and lacking turbos?
Just factor an extra 3K in when buying one, you'll need it soon enough for an engine rebuild![]()
********... just because you had a bad experience, doesn't mean they're all bad.
Mine didn't give me a single unexpected bill. Never had any starting issues... got 26MPG on a run, 20-22mpg combined... and drove rather well for a car that only cost £3k to buy.
Either you or the previous owner(s) of your car didn't know how to look after it.
Did yours hit 60k miles?
Autotrader is full of them at 60k miles for roughly 3500quid, can't be that coincidental
here another 231bhp RX-8 dyno tested
Max 177.2 HP (fly)
Max 146.7 HP (wheels)
The feeling I have right now is that it handles better than my current car, 370Z Roadster...but really it's likely that the RX8's handling just left such a good impression!
