Basically if you fork out loads for something, you want it to work as it should. But if you buy cheap stuff, its not the end of the world if its a tad rubbish..
But this is what I dont get, ppl spending hundreds and maybe in the 4 figgure sum on crossfire/Sli and it dont always do the job its ment todo. But a £50-£300 single card/gpu you can guarantee to work as it should. Something is just not right their somewhere, dont you think
I know what Id go for everytime,, But saying that I wouldnt mind messing about with crossfire/sli, to see what numbers I could get, but for games its a tad pointless as no game runs even slightly chuggy without multi cards or gpus and even more so now as most games are ported rubbish. Before you say it,, if you use more then 1 screen for gaming, buy the the fastest single gpu card thats out, as Im sure it will still run fine without multi gpu's and a hell of a lot cheaper too, I bet.
Edit: Na, the more I think about sli/crossfire, the worse it gets, as you just adding more things to go pair shaped, plus the motherboard might not get along with the cards, let alone the games not liking it.. Keep it simple guys.
