Basically if you fork out loads for something, you want it to work as it should. But if you buy cheap stuff, its not the end of the world if its a tad rubbish..
But this is what I dont get, ppl spending hundreds and maybe in the 4 figgure sum on crossfire/Sli and it dont always do the job its ment todo. But a £50-£300 single card/gpu you can guarantee to work as it should. Something is just not right their somewhere, dont you think
I know what Id go for everytime,, But saying that I wouldnt mind messing about with crossfire/sli, to see what numbers I could get, but for games its a tad pointless as no game runs even slightly chuggy without multi cards or gpus and even more so now as most games are ported rubbish. Before you say it,, if you use more then 1 screen for gaming, buy the the fastest single gpu card thats out, as Im sure it will still run fine without multi gpu's and a hell of a lot cheaper too, I bet.
Edit: Na, the more I think about sli/crossfire, the worse it gets, as you just adding more things to go pair shaped, plus the motherboard might not get along with the cards, let alone the games not liking it.. Keep it simple guys.![]()
I have not posted for a while, but just to let you know I have solved all problems.
No blue screens, no crashes, no issues at all. I got my 2nd card back, and everything is running like a dream.
My eyefinity running:
Thanks everyone for the great support. It was very helpful for me to go through that nightmare.
I agree with phil, i went a blew loads of cash on sli gtx 580's and three screens etc. however nor all games supported the high resolution etc and also my pc and gpu temps went through the roof. I now game on one gtx 580 and a single 24" benq and i am so happy now as i no longer have a chuggy hot pc and every game works!
Crashing problems were caused by drivers, AMD drivers.So how did you fix the crashing problem? Upping NB voltage? Did you try another PSU?
Drivers I'm using just now are 12.3. Best drivers so far, no issues, quite a big jump in performance as well.
No it was not. When I sent the faulty GPU for RMA, I then changed the drivers while using the single one.It was crashing with the new card you bought with other drivers ?
Crossair that's some setup you got there fella, well jealous![]()
I have 12.3(8.95-120214a) prelease version, they are working amazing. Totally no issues, and BF3 works fine too.@Corssair. What games do you play? the 12.3 ones made a lot of texture/map dissappear on me in bf3, which is what i play most. So i had to revert back to 12.2 precert and 12.1 either cap 1 or cap2. I'm not sure how to check.
