**NVIDIA GTX 480 IS BACK - TRULY INCREDIBLE PRE-ORDER DEAL!**
They pull around 650/ 700w while gaming
No they don't.
They pull less than half of that.
:Edit: Just realised you meant that combined they use about 650/700w... yeah I'd still say that's a slight exaggeration but better to be safe than sorry definitely.
MSI Afterburner shows the rpm. I ask because I have had Asus GTX 480 which had if I remember right, 2040 rpm idle. Gigabyte GTX 480 has 1620 rpm at idle. So there's a massive difference in idle noise.
I'd just like to know to which group this belongs to.
1620 rpm rings a bell so I would say that, it is quiet on idle my case fans are
louder!
I got a Artic twin turbo 2 it got a better review than the Geild icy. ;)
The maximum a 480GTX can draw is 300W I think (75W via slot, 75W 6-pin, 150W 8-pin), so unless you have SLI cards or an overclocked Bulldozer/SB-E drawing 400W then a 750W PSU should be easily enough for most systems.
PCI-E 2.0 slot is 150W
so 150W +150W + 75W :)
one of the reasons why I think my 480 needs way more volts than it should as I'm running it ona PCI-E 1.1 slot
I seem to remember reading somewhere about this and there were 2 points of view:
1) that the PCI-E 2.0 specification allows for 150W through the PCI-E slot but that this has never been implemented by any motherboard manufacturers
2) that "150W through the slot" was misunderstood and it actually referred to the 150W 8 pin PCI-E power connector from the PSU
Either way I believe a PCI-E 2.0 slot still only delivers 75W.
Hi guys well am happy as a pig in s***! :D
New cooler fitted result!!!
Stock cooler
idle 45c fan @ 44%
load 92c fan @ 79% LOUD! :eek:
Arctic Twin turbo 2
idle 36c unkown fan speed but silence! :D
load 65c SILENCE! :)
Same test evga furry stress test for 10min!
Didnt someone say they were rubbish! :cool:
Stock cooler
idle 45c fan @ 44%
Arctic Twin turbo 2
Thats superb :)
Stock cooler
idle 45c fan @ 44%
Arctic Twin turbo 2
Glad to hear your happy with it!!
Itchy, got any pictures with it installed?
Interested to see it fitted.
Cheers
Will do later, she needs a clean anyway!! :)
Oh yes when i removed my case I dont have a 850w icute power supply, its
700w :eek: ...lol even worse! I remember now my psu went pop and the missus was in town I said get me a psu from ......, I had seen an 850w on offer when she got there they hardly had anything in.
So thats the story of how me and iCute got together it was ment to be ! :D
Dont think I am going to get much overclocking done with 700w! :p
Quick update after playing skyrim last niight for a few hours and monitoring temps the card reached a whopping 70c! :D
Side note internal case and cpu temps got a little high until I turned the case fans up to 2.
How long did the curing take for you in the end itchy? I ended up having to leave mine for over a day :o
And the glue on the TT2 can be rubbed off with your finger, so you can re-fit the cooler on multiple cards with nothing more than some more of the adhesive compound.
[edit] AXLAndy, that picture you have shows the Twin Turbo. The cooler me and itchy are running is the Twin Turbo 2. I believe it's been upgraded which is where the discrepancy between your experiences and ours comes from.
Here are some pictures camera is rubbish really hard to focus!! :mad:
Hope it works! I aint posted pics for a long time on the web! :p
Picture 1
Happy hour on the thermal paste at EVGA !!! :eek: Naught, naughty! :rolleyes:
Pic 2
Side by side the stock cooler looks like a brick and works like one too! :D
Pic 3
Top down view, yes it does take three slots up but worth it!
pic 4
Heat sinks oh so many heat sinks!! :eek: Spot the botch job because they only gave me 11 memory sinks, the 480 has 12! :rolleyes:
pic 5
In the Pc with a few bits removed to see better!
Pic 6
Altogether ready to go, the long black cable is the second MB power lead and its too dam short in a p190, was with my other psu just about stretches over the new cooler! ;)
It was not easy to fit had to improvise here and there but done it the end.
PVA glue is a godsend! ;)
6 Hours then the hair dryer came out, the glue i had left was only just setting this morning. 5 hour cure my a..e! :mad:
I know but she will be getting retired soon then i will sort the wiring out!;)
Thanks Itchy looks good mate good job.
Aside from a ram sink short did it come with enough sinks to do the VRMs? it looks as though it might.
Yes VRMS and few others, I had to use two halfs for the last mem chip so was short for 4 small chips and as you can see from the pic i used 2 L shape types that just about fit! ;)
Hope you get a new PSU when you get another case and call the bomb squad to get rid of your iCrap! :D
yeah if it's true about 2.0 specification supporting 150W through the slot then it might just be that for backwards compatiblity reasons it was never adopted and they decided to make use of the PSU connectors instead, I'd imagine the 6-pin/8-pin straight from the PSU offer a cleaner supply too.
iCrap! how dare you!!!! :D Its iCute and she is modula and has a sexy blue light coming from the fan :cool: but you cannot see it in a P190! :p
looking good itchy! how much did you have to spend on the aftermarket heatsink?
£40 all inc next day del! Oh and about 2-3 hours of your time sticking the bloody thing together, fiddly as @!£$, but worth it! ;)
