Something wrong
didn't have realtemp running had coretemp though that was showing 60
That reading of 60 seems dodgy. If it's a bust sensor that toggles between 60 and 120 then that could cause the intermittent cut outs especially if you have CPU temp protection on in the BIOS (usually a default)
Sort out the CPU cooler first to ensure that it's well seated.
ok, how do I know if its incorrect? i need to re-apply the paste i presume? if so how do i cleanoff the old stuff? i really could cry about now lol sad cow. thanks for your help! x
I assume it's the standard HSF that came with the CPU right ? If so... all 4 push pins must be firmly in place. How hot is the heatsink when you touch it ?
Also can you post a pic of the inside of your case ?
it just locks up/seizes and i can't do anything can't get mouse to move, keyboard input doesn't work either so can't ctrl/alt/del i have to turn off at wall and turn it back on again.
Have a look through your event log for clues.
Remove the d2x and repeat the test. Full load cpu and gpu ... see if it locks up. Gradually continue to a remove components right down to 1 stick of ram, cpu and gpu
.... and whilst you're at it, get me that cuppa .... 2 sugars please TA
