[TW]Fox;21509468 said:A high proportion of the M54 engined BMW's will happily guzzle a litre of Castrol Edge every 1500 miles and they don't seem to get half as much stick as the RX8 does for it.
[TW]Fox;21509553 said:It's very common but mostly affects the 3.0 and 2.2 litre variants.
Nor do i want huge cars that only go in a straight line or handle like boats
Very few, an S2000 would be a nail at that cost, so your looking at MX5s or older (and arguably unreliable) metal.What other cars of similar spec and power can be had for around £3.5k?
Ignore the scare mongering.
Pick a good one and maintain it properly and it's unlikely to be an issue.
That said - you still need to be prepared for such an outcome - if a blown engine is going to ruin you then you should consider something cheaper.
There are plenty of cars that can and will throw bills just as large, though.
If, however, you have a decent disposable income but still want a cheap car that handles beautifully when on the boil, then go for it.
You are exactly like me CraigN. But after reading all the stories on here about the engine will go bang, not it might but will has somewhat put a downer on the RX8 for me over the past few days. I want to get one and the 231 seems an perfect car for me.
What ballpark costs are we talking about, I have seen cambelt changes and turbo fails that can be very costly, how does the rex compare?
