- 14 Dec 2009
I saw 2046mb vram usage on Caspian border last night (1920x1200 ultra).
That's so mad....
That's weird, I've not seen it use anywhere near as much VRAM on Caspian or any other map on Ultra, same res with 2xMSAA/16xAF and HBAO.
Maybe ATI cards do it differently...
The game does use a lot of system RAM though, around 2GB at times.
or do you have the 2500mb version?I get 99% on both cards all the time.
Still on 12.1a with the 8.95 drivers from the 24th Jan.
Just 11.11 CAP3 afaik.
Everything is running smoothly (all current games I'm playing) so no need to move to 12.2/12.3 with newer CAP's
Those are the ones I had, foolishly put 12.2 on and BF3 fps plumited. Used driver sweeper to get rid of all traced of 12.2 and any CAPs then put 11.11 CAP3 back on but Im still only getting 50-70% usage on both cards![]()
I never could understand how some people swore by that app when you've just proven how useless it is.
Take it you had no joy as your cards are now up in the mm![]()
However when I switch on the MSI Afterburner framlimiter to 59 and VSYNC in game the GPU usage goes back to around 70%... is that normal? Logically it is because Im limited the FPS, without these two on I'm getting around 80fps but 99% GPU usage.Having reinstalled Battlefied 3 (uninstalled in Win7, deleted all folders associated with it) I am now using 99% on both GPUs againHowever when I switch on the MSI Afterburner framlimiter to 59 and VSYNC in game the GPU usage goes back to around 70%... is that normal? Logically it is because Im limited the FPS, without these two on I'm getting around 80fps but 99% GPU usage.
