- 7 Jul 2010
Well thats your problem.
VGA and HDMI are diffrent so can't be converted passivley.
Awkward..
I saw that earlier as well! Will finish up the build when I'm home soon. Thanks for pointing me in the right direction, just ripped the boxes apart thinking I'd lost the allen key!![]()
Also email them your form, its quicker.
where do i e-mail it, and do i need to print it out and fill in and scan back in?
Have you installed the 6450? Mine arrived and I am about to. Just wondering what drivers you are using (if you have even loaded an OS yet?).
rp2000
Yep, got it installed and working fine! Just finished setting up Windows 2008, about to move it downstairs where it'll stay.
I just installed these drivers: http://www.asus.com/Graphics_Cards/AMD_Series/EAH6450_SILENTDI512MD3LP/#download - Windows 7 64bit ones work fine!
Can anyone confirm how to fit a 2.5 inch drive into the microserver? I have just purchased a ssd and wondering if I need an adaptor to fit the drive in?
) I just bought an Icy Dock case and that did the job perfectly.[RB];21535319 said:Cheers rp,
When I looked last time I couldn't find any stock.
There do seem to be 3 alternatives that all do the same job:
[1]Feser Silent Arrow
[2]Noise Blocker NB-X-Swing
[3]Nexus DoubleTwin
The silent arrow I can only find in the states, X-Swing seems to be discontinued and the Nexus seems to be in stock so I've ordered one.
Will report back on if it fits!
but is sturdy on 3 mounts.Well thats your problem.
Did your SSD come with a 2.5" to 3.5" bracket?
The OCZ bracket, even thought it claims to match the layout of a 3.5" drive is off by a few millimetres. That is enough to make it not fit in the Microserver caddies. Crucial claim the same for their bracket and I even found a posting on their forums claiming it would work in a microserver (in repsonse to an owner's query).
In the end (after wasting money on the OCZ bracket) I just bought an Icy Dock case and that did the job perfectly.
rp2000
?Thanks can you please confirm the model of the IceyDock?
Icy Dock MB882SP-1S-2B 2.5 inch to 3.5 inch SATA HDD/SSD Converter - Black
£11.48.
rp2000
