SSD Transfer kit?
13 Jan 2004
Leicestershire
I see with some you can this as well as the SSD drive but what is it?
had a look but can't see any clarity. Is it a fitting kit to fit the 2.5" drive into a standard 3.5" HDD slot?
Would an SSD fit into say a floopy drive mounting (assuming that's 2.5")?
yes it will fit a floppy drive bay,think its a fitting kit but mine came with one
could be software to transfer os to ssd ?
but what is it?
This is the crucial M4 one
http://www.crucial.com/store/partspecs.aspx?IMODULE=CT128M4SSD2CCA
Transfer everything in a few easy steps
The Data Transfer Kit makes it simple to copy everything on your hard drive, including operating system, data, email settings and applications, to your Crucial m4. The kit includes the EZ Gig III Cloning and Imaging Software for Windows®, ShirtPocket's SuperDuper! for Mac®, a USB to SATA cable and a Quick Start Guide. Upgrade your notebook drive in just three simple steps.
Ah right cool!
So if i was doing a clean install anyway i wouldn't need it. Cool.
Cheers!
Was just wondering about the2.5" to 3.5" as that's going to be the main problem - unless they come with the stuff to mount it?
Ah right cool!
Cheers!
Just use velcro tape. Couple of quid and works a treat.
