What is the best way to clean an engine as a result of neglecting oil changes? A friend of mine has missed a few services and after realising the consequences of not changing the oil, is (rightfully) becoming paranoid.
I have done a little reading into it, and from what I can see, it is advised not to use any kind of 'oil flush' solvent and instead, simply either remove the valve cover and inspect the engine condition.. or buy cheap value oil of the same grade, run the car for 20 minutes before draining and replacing with a good quality oil.
What else can be done? My knowledge is limited, so hopefully someone could offer some additional advice
