i was hopeing someone could help me with this question i have to do for homework, which is from a text book, so i do have the answer, but it is difficult.
Question - Particle A of mass 1kg is at rest 0.2m from the edge of a smooth horizontal 0.8m high table. It is connected by a light inextensible string of length 0.7m to a partcle B of mass 0.5kg. Partcle B is intially at rest at the edge of the table closest to A but then falls off. Assuming B's initial horizontal velocity to be zero find the speed with which A begins to move?
thank you
thank you
