- 29 Dec 2003
- Denton
Has anyone's phone been allowed to update yet? Mine is still waiting.
It specifically says "HSPA+ Galaxy Nexus ". Not us yet![]()
Manual update to 4.0.4 if you want to try:
http://m.androidcentral.com/how-manually-update-your-gsm-galaxy-nexus-android-404
Has there been an official update from Swype for ICS yet?
Yes, it's been out for about a month now. If you've got the installer on your phone, just double tap it to run and it should install the latest version.
Thanks!Manual update to 4.0.4 if you want to try:
has anyone got Launcher2.apk from a stock (non deodexed) 4.0.2 they can upload somewhere?
verifying current system
assert failed: apply_patch_check("/system/app/Launcher2.apk" , "1a858cfb5c270cfc04f37545caa73b9d4c1687f8" , "d1c387c565d83c3f68daebbf07a332a9ebb770e7")
E:error in update.zip
(status 7)
install aborted
I've extracted Launcher2.apk and Launcher2.odex from the 4.0.2 factory image and the sha-1 matches:thanks, unfortuately i'm getting the same error, it must mean something else.
