- 20 Jul 2009
- The bleak North East arm pit of Britain
Is it just me or has OCUK suddenly become the Max Power of computer retailers?
Looks good thoughand the new ranges
Could I suggest you try and filter down the Bitfenix cables in some way? There's tons of them and when I was looking I found it a wee bit difficult to manage. Perhaps if you could have a category for each colour then it might be easier to shop? I did try a search, but it didn't turn out the right result.
Any idea if and when you'll have any NZXT PSU's Andrew?
This is something that is being discussed at the moment and will eventually happen, there is no set time on this at the moment though but Ace Modder or one of the team will provide information to the forums when it does happen![]()
Search "Alchemy" followed by the colour you want.
EG
Alchemy red
The first results are Alchemy products that are red, followed by all alchemy products, followed by products with the work red.
No need to filter really, it would add too many sections to the website unfortunately.![]()
Type alchemy red or alchemy black, see what comes up!
The same as it would if I typed alchemy red black.
It assumes an or between search queries and ranks them in order of hits. So if there was a black and red alchemy item it'd be top.
It does do what's needed I guess, but it's not ideal, and I'd like an AND function on it, just because it's tidier and plays to my slight OCD.
My phantom didn't come with one of those.![]()
