i7 CPU not showing 8 cores in Win7 Task Manager
14 May 2007
London
Hi,
After installation I see 8 CPU's in Windows Task Manager.
I install a few OC utilities - includiogn the Gigabyte and Intel tweaker, reboot and now I only see four cores......
I remove the aforementioned applications. I still see only four cores...... :(
What did I do..... ????
Thanks.
Sorted it. Guess what....
run>>msconfig>>boot>>advanced_options>>number of processors
I manually set this to four since I read somewhere that when windows boots it only uses one core. And this is where you change that behaviour. So I set this to four so it uses four cores during boot. Guess what? this limits it to four full stop!!!!
Thanks anyway guys - apprciate your time.
