The tank most likely had reactive armour on then. I always just place as much as possible just to be sure with the extra explosive damage perk!![]()
IMO what would be best for tanks (completely stock) are as follows:
- 3 JAV to rear and sides to disable it, 4 to destroy
4 JAV to front to disable it, 5 to destroy
And one more rocket required for the RPG/smaw.
- 2 C4 on the rear/sides to completely destroy, 1 to disable
3 on the front to completely destroy, 2 to disable
- 2 mines to completely destroy and 1 mine to disable
DG will most likely disagree and say that only one rocket, 1 c4 etc. should completely destroy a tank and that an entire mag from the usas with frag rounds should destroy a tank!![]()
5 JAV to destroy a tank... Are you mad?!?
How many do they take irl ?
No. Just no.
If that were the case, then you would have to get rid of the repair tool entirely, else engineers will make a tank completely invincible. An engineer only gets (iirc) 3 Javelins as standard - that would propose taking away their ability to destroy a tank without the explosives perk. One hit disable, two destroy - tanks can evade lock with smoke, evade lock by moving and get repairs......
It was perfect!
Can't believe the amount of team work in softcore mode!
My battlelog stats have been reset, tried different browser login logout, all how no stats.
http://battlelog.battlefield.com/bf3/soldier/LoCk3H/stats/315694387/
what the hell has happened?
