- 6 Jan 2011
- Stoke on Trent
Hi after some deliberating , I have recieved now a crucial m4 128gb ssd , I understand I have to update the firmware .
Question is do i do this before anything else , I have just unpacked the ssd , plugged it into an existing 775 desktop i have , to check it is working , and it shows up in the bios fine .
However it is just out of the box , so it doesnt show in windows , Do i have to format it first and do as i would with any normal mechanical drive , should i do the firmware first . if indeed it will work , before i format it , Do , i need to format it at all ?
Iv got the firmware sitting on my desktop , ready to run the application through the windows utility , rather than burning disks .
I will be using it for a new ivybridge build , but thought ill connect it to another pc and sort this first , so its ready to go .
Thought illd ask you guys first before i mess it up and do it wrong way round .
many thanks in advance .
