If you're using that water to cool a CPU, the water will be hotter...so if you lock a box full of 50% of water and 50% of air lets forget about volumes here as in rooms etc
say a cube half water and half air the water will always be a lower temp than the air ?
if so great .. but i cant see it
The problem with a Hailea unit is that it just dumps heat straight in to the room it's in, not just the heat from the PC, but also the heat it generates from actively cooling the water with a refridgerator - typically 100-200W for something sized to deal with a modern CPU. You would need something with a flexible duct and run it to a hole in the wall or out the window and have the waste heat carried out the room like that.i want to keep my room comfortable without pumpin tons of AC controlled air into the room cause it gets a bit chilly, but dissapate the heat from the pc so it doesnt effect the ambient and therefore not kick in my ac as much. if you see what i mean.
so the thought was a chiller with an external vent so no heat is dumped into the room similar to my ac without me feeling cold but am not sure of the best way to do that
added
no i dont want the rad outside the room as in the summer i would be worse off tbh than just having my ac on
If you've got an ac duct, you might as well use it for your radiator, it'll be a far more cost effective means of getting rid of heat.yer i have an ac duct that i can use for the unit so thats not a prob tbh i will connect the exhaust from the chiller into my AC ducting ..so any heat from the unit will go directly outside, the only thing is the unit i guess as in the body will also get hot . that may be more easily hadled by the AC so as i dont have to run it so much and sit here cold.. when it kicks in so often..
tryin to chill pc with less room heat dump is what its about..
is there a alternative to the Hailea? or are they the only really small effective units 250 - 300 quid is okie as a expense i guess so thats not the prob so the 100 range ?
http://www.hailea.com/e-hailea/product1/HC-100A.htm
Nope. When you start with everything off, everything is at ambient, when you turn it on, the CPU produces 100W, heating the water, which in turn heats the air. For the water to transfer 100W of power to the air it needs to be say 10degC hotter than the air.surely? the water will remove heat from the cpu then that heat will transfer into the room eventually the room will heat up and the temps will equalise within a degree or so .. im not talking absolute but the ambient will get to close to the water temp and then consequently the cpu temp.. i accept they wont be = but the point is they will grow closer as in +/- a degree or two
we all know that water is more effeicient at removing heat than air, but ultimatley all water is doing is delaying the process of your pc heating up longer than an air cooled system. as when you water reaches the same temp as the temp in your room it will then gradually increase warming the ambient at the same amount untill everything is the same temp,
obviously the bigger the room the longer this will take but we cant increase the size of out rooms easily. yes you can open doors and windows in the winter but opening a window in the winter will have the same effect as having aircon on all the time. and in an attempt to kool your pc you may have to suffer cooler than comfortable room temps.
so water chiling is the only real answer to nice comfortable room temp and a cold pc.
what a long winded way of asking are there many options other than Hailea water chillers? as sometimes i dont really want to put the aircon on just to keep ambient temps down as the room warms up a hell of a lot
and if i can chill my water and keep pc kool but still in a comfortable room not to hot and not with ac on all day would be nicer
hailea or anyother ideas ?
i say go for it mate if your a pc overclocking junkie like me
