Dyslexia
Interesting thread.
I'm curious as to what exactly a 'Dyslexia Test' is.
Also, I'm not 100% convinced that Dyslexia exists yet.
you're normally put though a load of tasks involving different skills (shape and space, reading and writing etc) and it's not normally a "dyslexia test" iirc it's for a range of different issues.
I'm dyslexic, have a fair few problems with reading and writing.
Still spend more than enough time agonizing over my posts to make sure they are fairly readable. Wish more posters on the internet gave the same curtsey
I lol'd :D
I think this all stems back to what people are actually doing about dyslexia, or for the those who truly have it.
A couple of my friends at university have "dyslexia" (I'd be doing bunny ears with my fingers if I could), as it meant they got free MacBooks. The state just throws money at them to make the problem disappear.
No it doesn't.
My brother has dyslexia he has no qualifications, he can read fine but can't write or spell too good yet he earns 45-50k a year making sure this country's electrical supply keeps flowing.
He worked hard and people noticed, if you blame dyslexia for not getting anywhere your'e just lazy.
No it doesn't.
No it doesn't.
How hard is it for a more able person to fake having dyslexia? There's no medical tests that are a true/false result, it's all based on the opinion of a supervisor, surely.
It depends which model of diagnosis the local authority uses. Some use the discrepancy model (normal IQ, reading/spelling below a certain level), some use a multidisciplinary approach, some authorities allow just one professional to make the diagnosis.
There are empirical ways in which it can be 'evidenced' but they are all based on the proviso that it genuinely exists, and can be measured in a quantitative way.
Which is what I have alluded to a few times. There are other ways of maybe approaching this without labeling unnecessarily which seems to be a common theme in the threads where we meet!
I do think there is a fundamental problem in describing the actions of the brain in terms of "normality" and "abnormality" when there is more variation than we can appreciate. What we do is apply a quite rigid medical positivistic framework onto something that can not accept it. There is a big difference between saying something that is quite linear is abnormal, for example a blood result with a known quantifiable value, and something that is quite non-linear and unmeasurable, for example learning and behaviour. In the case of such things then we need to be aware of all the facets of the problem and approach them specifically for the people concerned not do what we currently do. The is a time for protocols and procedures when things are clearly delineated and at such times it makes sense to place people into them but when we have such complexity it makes sense to adapt our protocols and procedures to people so we maximise both efficiency and efficacy. I just think we inappropriately label people and then overburden the provision for such people whether they need it or not leaving a shortfall for people who may have significant problems but fail to meet the goals of measurement. Because such a measurement will be prone to misinterpretation, subjectivity and in all likeliness bias.
I posted above that I worked with 2 testers a couple of years ago and because dyslexia is complicated (and not just about reading & writing) even them knowing all the tricks would find it hard to trick another tester.
Sitting a test and pretending not to read and write wouldn't cut it.
I have no problem reading and have never considered myself dyslexic. I actually enjoy reading a lot. But I do seem to mix words up a lot. I tend to write/read words that sound similar to the word I was trying to write/read.
