Man of Honour
 - 27 Sep 2004
 - Glasgow
You're probably right Waster. It's quite depressing,
It's not exactly a surprise though, the viewpoints and the battlelines are too firmly entrenched to allow for much movement. It would however be nice if people would stop putting up facile positions and stating they represent the views of the other party.
Which doesnt work for 74% of criminals.
Poorly implemented rehabilititation doesn't work for 74% of criminal, it's not quite the same thing as saying that 3/4 of criminals cannot be rehabilitated which is what you are either stating or trying to imply.
Norway does it better at around 20% recidivism, Sweden manages somewhere below 40% recidivism so that would appear to indicate it is possible that rehabilitation works in some cases and could potentially work in more than the 26% you keep highlighting. That's unless we believe the premise that some nations are inherently criminal or impossible to change - I happen to believe neither of those therefore I think that it's a question of approaching it in the right way. Unfortunately from some points of view rehabilitation when done properly is not cheap and does not appeal to those who view Old Testament justice as the preferred solution - it does not and cannot work for everyone, there will always be people who cannot be reformed, just as there will always be those who choose to abuse whatever system you put in place but it's worth persevering with.
