It's nice to see so many people taking advantage of the clear weather today by getting out on their bikes. I only managed 56km this morning, but there were loads of cyclists out, as well as joggers too - though I suspect the latter was due to it being the Croydon half marathon today. I managed to get through a ride without losing all feeling in my feet for once, which was a bonus. I just hope that the weather forecast for the next week is wrong, and we get more days like today...
Need to increase my distance, I really want to have a crack at the Blayney to Bathurst in three weeks time, the short course is 70km.
21km this morning quite easily, I find I can cruise at about 25kmph riding alone without using too much energy.
Think its do-able or would I be in for a world of pain?
If you can do 21km easily then you'll most likely be able to do a 70km ride, however I would imagine you'll be pretty knackered at the end. If you have time, try to do a 50km ride at the weekend and see how you get on. If you struggle then you know the 70km ride is going to be a "world of pain", as you put it.
Also any recommendations for a mini pump to ride with suitable for road tyres, my MTB one won't give enough pressure.
I have a
Topeak Road Morph with Gauge which I've used to inflate a tyre to 110psi after a road-side tube replacement - the description says it'll go up to 160psi and that seems believable, but I wouldn't want to actually try it. 110psi wasn't too difficult to achieve, and having a gauge was more useful than you might think. The downsides are that it's pretty expensive, and getting additional brackets can be tricky, as they tend to go out of stock very quickly. The bracket is very secure, as it uses a plastic clip and a Velcro strap, though it does cost you a bottle cage as it can't sit alongside one as some brackets allow for. Oh, and it's also quite long, so check to make sure you can mount it on your frame (it's too long to fit on my 26" wheeled hybrid, for example).
Some people swear by CO2 pumps, and while they're certainly more convenient, once you run out of canisters you can't use the pump. It's something I'd rather not worry about, hence the manual pump.
