- 13 Jan 2004
- South East
I've had a few cheap wheels and two genuine OMP ones, would never go cheap again after having one bend on me. You can feel the difference in the finish as well. Nothing worse than feeling the wheel flex as you corner hard
Started work on the switch panel...
A little mock up to check things fit, the back of the isolator JUST fits in between the gap, its literally the exact width of the plate. Gonna have to think of another way of securing it as the security cage fouls the isolator when its in, metal + live wires don't mix well together. Still waiting for the toggle switches to turn up, but with the half the panel free, these will fit easily :nickd:
http://www.msphotography.net/clio182/IMG_1360.JPG[img][/QUOTE]
How will this work? Do you still need to put the normal key in for ignition?
