I've read the Cyanide FX6100 review (A nice and honest approach! Budget gaming chip and that's my normal market!)... and read the AMD bashing thread
that followed.
I can say that 'cos I've only build budget AMD gaming systems, since socket A
Athlon 1Ghz (with a moderate OC and like to buy slightly higher end RAM...) they never let me down and generally cost a lot less ££ than Intel!
I've set my sights a little higher than normal (as this list is still almost current
) and thinking it has some scaleability and I'm looking at the Gigabyte GA-990FXA-UD3, Crucial 8GB (2x4GB) DDR3 1600Mhz Ballistix Tactical Memory Kit CL8 (8-8-8-24) 1.5V, with an FX6200 3.8Ghz, but can I find an owner / review of this latest 6 core AMD?
...I suppose the "can i find an owner" comment will let lose the FX bashers
again...
My thinking is that if the 6100 / 6200 doesn't work out; I can upgrade the CPU to the next generation if the gossip is good about AM3+ chipset.
...your thought's welcome on the FX6200 and options above! Is the Tactical (8-8-8-24) worth the extra cash over the Sport version on this weeks special?
that followed.I can say that 'cos I've only build budget AMD gaming systems, since socket A
Athlon 1Ghz (with a moderate OC and like to buy slightly higher end RAM...) they never let me down and generally cost a lot less ££ than Intel!I've set my sights a little higher than normal (as this list is still almost current
) and thinking it has some scaleability and I'm looking at the Gigabyte GA-990FXA-UD3, Crucial 8GB (2x4GB) DDR3 1600Mhz Ballistix Tactical Memory Kit CL8 (8-8-8-24) 1.5V, with an FX6200 3.8Ghz, but can I find an owner / review of this latest 6 core AMD?...I suppose the "can i find an owner" comment will let lose the FX bashers
again...
