**NVIDIA GEFORCE GTX 680 4GB ARRIVING NEXT WEEK - PRE-ORDER NOW!!**
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
As always, OcUK is first to market and we've secured a large volume of stock on these two great and very cool cards from Palit, pricing is also excellent:-
Palit GeForce GTX 680 Jetstream 4096MB GDDR5 PCI-Express Graphics Card @ £539.99 inc VAT
The GeForce® GTX 680 delivers more than just state-of-the-art features and technology. It gives you truly game-changing performance that taps into the powerful next-generation GeForce architecture to redefine smooth, seamless, lifelike gaming.
Immerse yourself in an ultra-smooth gaming experience with exciting new NVIDIA technology advancements like NVIDIA Adaptive Vertical Sync. It’s a fast, seamless way to adjust VSync to your current frame rates for maximum playability.
Features:-
- Innovative new GeForce architecture, designed to deliver faster, more power-efficient performance
- NVIDIA GPU Boost technology that dynamically maximizes clock speeds to push performance to new levels and bring out the best in every game
- The power to turn on lightning-fast anti-aliasing in a huge variety of games, automatically, with NVIDIA FXAA
- The power of 3-way NVIDIA SLI® technology
- Ultra-smooth gaming experience with exciting new NVIDIA technology advancements
- NVIDIA Adaptive Vertical Sync adjusts VSync to current frame rates for maximum playability
- NVIDIA 3D Vision® Surround multi-monitor gaming on a single GPU (three gaming monitors plus one accessory display) - for the first time ever
- Supercharged NVIDIA PhysX® and NVIDIA 3D Vision® performance
- New 28nm process means cooler, quieter and far superior overclocking potential than previous generation graphics cards
Specification:-
- Palit Own Design GeForce GTX 680
- The King of GeForce GTX 680
- Innovation JetStream Cooler Design
- Overclocking Performance
- Extreme Cool
- Extreme Quiet
- TurboFan Blade
- Blue LED Lighting
- 6-Phase Core PWM,
- 2-PhaseMemory PWM
- DrMOS-Power Efficiency
- 3 DVI Monitors support
- Core Clock: 1085MHz (GK104)
- Core Boost Clock: 1150MHz
- Memory: 4096MB GDDR5
- Memory Clock: 6300MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 1536
- Shader Clock: 2168MHz
- Bus Type: PCI-Express GEN 3.0 (Backwards compatible)
- Display Connectors: 2x Dual-Link DVI-I, 1x HDMI 1.4a & 1x Displayport
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption (Maximum consumption 195 watts at stock speed)
- 2x 6-Pin PCI-E Connectors required
- Card Dimensions: 270*111.15*38.75 mm
- Warranty: 2 Years
Only £539.99 inc VAT.
ORDER NOW
Palit GeForce GTX 680 Jetstream 2048MB GDDR5 PCI-Express Graphics Card @ £459.95 inc VAT
Features:-
Specification:-
- Extreme Cool
- Extreme Quiet
- TurboFan Blade
- Blue LED Lighting
- 6-Phase Core PWM,
- 2-PhaseMemory PWM
- Memory: 2048MB GDDR5
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 2 Years
Only £459.95 inc VAT.
ORDER NOW
Must resist! My KFA 570 is overkill for my needs.My KFA 570 is overkill for my needs.My KFA 570 is overkill for my needs.My KFA 570 is overkill for my needs.My KFA 570 is overkill for my needs.
Aaaaargh darn it all!
Im having the same problem with my 6970. My only excuse is that it runs loud! :p
well bit much for extra 2 vram on top 80 £ or so , also how come you find your 6970 running loud mine is fine never goes above 47% fan speed and above 71 celcius even playing demanding games for 3 hour sessions
My 570 runs loud. Coolermaster lied when they said the SIlencio 550 was designed for quiet and top end parts. If only I could find a case of almost identical or less dimensions whcih was plain and simple I might then get the 680 aswell!
I wonder just how many people use resolutions bigger than 2500x1600 to make full use of these cards? I guess it could be more about bragging rights though!
Don't forget 5760x1080, this is where it should count and make a good difference. :)
im on a 5870 1gb and game at 1920x1080 and am seriously considering a 680. just for the price/performance/futureproof leap. every other card i look at just doesn't convince me its performance is worth the price or will last the 4ish years i think i could get out of the 680 (before i estimate i'd need more grunt).
