**MORE CUSTOM & 4GB GTX 680's INCLUDING EVGA F-T-W NOW AVAILABLE!!**
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
KFA2 and Gainward have are now shipping us their super duper variations of the GTX 680. Take note all these cards use 8+6pin power connectors for better OC ability and vastly more powerful coolers yet still extremely quiet:-
KFA2 GeForce GTX 680 EX OC 4096MB GDDR5 PCI-Express Graphics Card @ £549.95 inc VAT
The GeForce® GTX 680 delivers more than just state-of-the-art features and technology. It gives you truly game-changing performance that taps into the powerful next-generation GeForce architecture to redefine smooth, seamless, lifelike gaming.
Immerse yourself in an ultra-smooth gaming experience with exciting new NVIDIA technology advancements like NVIDIA Adaptive Vertical Sync. It’s a fast, seamless way to adjust VSync to your current frame rates for maximum playability.
Features:-
- Innovative new GeForce architecture, designed to deliver faster, more power-efficient performance
- NVIDIA GPU Boost technology that dynamically maximizes clock speeds to push performance to new levels and bring out the best in every game
- The power to turn on lightning-fast anti-aliasing in a huge variety of games, automatically, with NVIDIA FXAA
- The power of 3-way NVIDIA SLI® technology
- Ultra-smooth gaming experience with exciting new NVIDIA technology advancements
- NVIDIA Adaptive Vertical Sync adjusts VSync to current frame rates for maximum playability
- NVIDIA 3D Vision® Surround multi-monitor gaming on a single GPU (three gaming monitors plus one accessory display) - for the first time ever
- Supercharged NVIDIA PhysX® and NVIDIA 3D Vision® performance
- New 28nm process means cooler, quieter and far superior overclocking potential than previous generation graphics cards
Specification:-
- KFA2 Own Design GeForce GTX 680
- Innovation Cooler Design giving powerful yet silent cooling
- Overclocking Performance
- Extreme Cool
- Extreme Quiet
- 6-Phase Core PWM,
- 2-PhaseMemory PWM
- Core Clock: 1110MHz (GK104)
- Core Boost Clock: 1176MHz
- Memory: 4096MB GDDR5
- Memory Clock: 6008MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 1536
- Shader Clock: 2220MHz
- Bus Type: PCI-Express GEN 3.0 (Backwards compatible)
- Display Connectors: 2x Dual-Link DVI-I, 1x HDMI 1.4a & 1x Displayport
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption (Maximum consumption 195 watts at stock speed)
- 1x 8-Pin + 1x 6-Pin PCI-E Connectors required
- Card Dimensions: 270*111.15*38.75 mm
- Warranty: 2 Years
Only £549.95 inc VAT.
ORDER NOW
KFA2 GeForce GTX 680 EX OC 2048MB GDDR5 PCI-Express Graphics Card @ £469.99 inc VAT
Features:-
Specification:-
- Extreme Cool
- Extreme Quiet
- 6-Phase Core PWM,
- 2-PhaseMemory PWM
- Memory: 2048MB GDDR5
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 2 Years
Only £469.99 inc VAT.
ORDER NOW
Gainward GeForce GTX 680 Phantom 4096MB GDDR5 PCI-Express Graphics Card @ £599.99 inc VAT
Gainward GTX 680 Phantom, continue the elegant design of the first generation. The new Phantom II comes with brand new fins design (patent pending) that introduces 1) better thermal performance 2) lower acoustic level 3) more solid structure than previous generation. With this new outstanding innovated thermal design and optimized product design Gainward GTX 680 Phantom delivers an extreme gaming performance for enthusiast gamers.
Gainward Grand-Prix Heat-Pipes Hybrid Cooler, was designed in 6 mm copper-water heat-pipes on a copper base conducting heats away from GPU at highest efficiency, then dissipating onto aluminum heatsinks, which are forced ventilated with Great 8 cm silent PWM fans (GR8).
Great 8 cm silent PWM Fan (GR8) achieves highest cooling performance at much lower temperatures under power saving mode.
Gainward provides 4 ports in one, fulfills universal connectivity to diverse displays in extreme high-definition resolution. Dual View is supported with ease without bothering connector conversion.
Features:-
Specification:-
- Core Clock: 1084MHz (GK104)
- Core Boost Clock: 1150MHz
- Innovative thermal design: Vapour Chamber (Quieter & Cooler than previous generation)
- Gainward 6+2-Phase PWM for improved OC headroom and power stability
- Memory Clock: 6300MHz (Effective)
- Memory Bandwidth: 201.6GB/s
- Shader Clock: 2168MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Lower power consumption (Maximum consumption 215 watts at stock speed)
- 1x 8-Pin PCI-E Connectors & 1x 6-Pin PCI-E Connectors required
- Warranty: 2 Years
Only £599.99 inc VAT.
ORDER NOW
4GB cards already! Nice :D
Shame about the PCB being slightly different for WC but those coolers should be nice and quiet without the need to WC!
Gainward looks especially nice
Those kfa cards look pretty good, the high stock clocks scream potential!
I have another Top Secret KFA2 card which has stock clocks beyond 1200MHz and is one of the most unique cards to exist, but you guys gonna have to wait before I unveil that one, could be an OcUK exclusive product too. :D
EVGA by the way are promising to get their 4GB and FTW cards available for pre-order next week. Signature and Classified also coming soon, now those are quick!
EVGA by the way are promising to get their 4GB and *** cards available for pre-order next week. Signature and Classified also coming soon, now those are quick!
LIKE :D
Definitely going to be buying something new and shiny once they stop bringing out new ones every 2 days!
top end GPU prices now, jezz :o
can quite easily buy a decent i7 bundle for that :p
owchy
