It's home!
But not without issues, and I need some advice on carbs.
It's running twin Weber 40 DCOEs and it has a spluttering problem at around 3k RPM. It doesn't do it when it's cold and presumably the auto choke is on, but does when its up to temp.
The spark plugs are pretty rusty so I'm going to change them to make sure its not an ignition problem, but fear that would happen across the whole rev range.
The previous owner told me the carbs were tuned at the MOT last month, but I can't help but think something needs adjusting one them.
This is the first car I have owned with twin carbs so any advise you be appreciated:
