8 pin slot on motherboard
7 Mar 2012
In a house
Hello
My new motherboard (asrock extreme3 990fx) has an 8 pin cpu connector but my psu only has a single 4 pin what difference will it make if I use single 4 pin instead of 8 on an fx8120 chip
Not up to scratch on AMD, but being an 8 core cpu i'd say it would be rather power hungry, 4 pin might be ok for lower models but i'd personally either get another psu or a 4to 8 pin adaptor (though this is not ideal). I could be well wrong i fully admit as i know literally next to nothing about AMDs in the last few years as i rarely build them and its all budget stock rigs when i do.
For that CPU I think you'll need an 8 pin.
I've ran an Athlon II X2 240 from a 4 pin in a motherboard with an 8 pin EPS socket but for a power hungry processor such as the FX-8120 I doubt it'd supply enough juice, especially if overclocked.
What PSU do you have?
You can get extension leads and even molex to 8-pin EPS adapters.
What PSU is it? If it hasn't got an 8-pin connector I'd guess it's either and older or el-cheap'o one.
Yeah I do have a cit 750w which has 2 4pins which I think I'm going to need to use once I get a cable with a 5 amp fuse since I already tried it with a 3 amp fuse which blew
Damn. They can be had for £30, not good. A new PSU is strongly recommended here!
What is your FULL PC spec?
mobo: asrock extreme3 990fx
CPU: FX8120
GPU: GTX 560ti
Sound:x-fi xtremegamer fatality pro
Ram: 16gb 1600mhz ram
I think that's it
Well for all we know CIT could be the next corsair for all we know
:confused:
With PSU's you get what you pay for. The G7 and generally all of CIT's PSUs are cheap, unbranded, generic turd.
You've got some expensive quality components there, I wouldn't risk it!
Spend £50-60 on a quality psu and it will probably outlast all of those components!
:confused:
Well said, don't settle for less than 80+.
Great PSU's can easily be had for £50.
:confused:
I just can't see why I should pay extra for the same product?
Your not really, the better quality PSU'S have the circuitry to stop any surges going through your components plus they will be able to maintain their output without issues and maintain stable voltages.
There have been threads were people have ignored our advice and the PSU has gone bang or they get shutdowns and stability issues.
That's probably true but I haven't had any problems with the g7 for past 2 years and I've not seen a negative experience of cit psu's do far
Just because you haven't had any problems does NOT mean the PSUs are good.
Voltage stability under high loads is something you simply do NOT get with cheap **** PSUs.
I've had a PSU blow taking with it *everything*. Luckily, it was cheap hardware but I always buy 80 plus Bronze or higher rated PSUs now.
Head the advice. Don't argue the toss. BUY A DECENT PSU.
