No - get a branded one. You only need 750W really unless you're going SLI.
Why is that no good?
"This 750W PSU is designed for entry level systems that require a lot of power."
Well that sums it up really. Your PC is not entry level by any means.
Can I just ask a quick question... Do you have something against branded PSUs?
some of the branded PSU's are generally good and well priced and those are alright but some are hideously overpriced for a low wattage
When it comes to PSUs it isn't all about the wattage though, that's the thing. You can have a 1200w PSU but it if has rubbish efficiency you'll not get anywhere near that, nor will you ever really need that unless you're going tri/quad SLI.
Anyways, the branded PSUs are always better, you get a nice warranty usually just in case, they are efficient and the wattage is suitable for what the user needs.
so what is exactly wrong with the one i linked except for it not being expensive enough?
Sorry - Are you not taking anything in? ._.
well so far people said about high quality and 80+
I think this is a lost cause folks!
You and me both.![]()
I think this is everyone's face towards the OP:
