7970 a good upgrade?
6 Jun 2005
Cambridge
Hi Everyone,
I'm looking to retire my old 4870x2 soon, and the 7970 looks like a good candidate, but I'm struggling to decide between the 7970 and the GTX680.
System is:
i7 920 @ 3.6Ghz
6GB RAM
GA-EX58-UD5 motherboard
etc
Is it worth holding out for the 680 to reduce in price a bit?
Many thanks,
15 Mar 2010
A 680 is a lot louder than the Sapphire 7970 OC Edition. It'll prolly perform on par/slightly better when OC'd, compared to an OC'd 680.
It's also cheaper
OP
6 Jun 2005
Cambridge
Is it quite easy/safe/not much difference in temps and noise overclocking a 7970 to 680 speeds? The Sapphire HD 7970 OC looks quite interesting
3 Feb 2012
Peterborough
The factory OC isn't really of any use but the custom fan can help with temperatures/noise.
I think both the 680's and 7970's are virtually silent while idle. I have a custom fan profile on my 680 and it reaches about 60% to keep it under 65c and I can hear it if I take my headphones off. But the only time it gets to that noise level is when I'm gaming and I always have my headphones on while gaming. So it's a non-issue for me.
I think the 7970's are similar in that respect.
17 Jul 2005
Yes, you certainly wouldn't want to game with a HD7970's fan running at 60% unless you had headphones. At 100% you wouldn't want to game unless the card was in a different room.
The normal fan profile keeps it under 50% in general gaming use which is noticably quieter.
19 Oct 2004
London
with a custom fan profile on my 7970 i can get 1200 stable at 62 degrees and 47 percent fan which is fine - with headphones on anyway
though the sapphire OCs at 370 are a bargain!!
