- 29 Jan 2010
what do you think current range of sandybridge prices will drop to once ivy bridge releases?
You may use a signature (commonly used in email messages) in your posts. You can specify in your profile a signature to use at the bottom of your posts. When you post, there is an option to use your signature. A signature may contain one or more images but they must fit within a box with maximum dimensions of 400 x 75 pixels (width x height) and with a maximum (combined) file size of 20k. Images containing mostly very large words or animated .gifs will not be permitted. You may also add 1 consecutive lines of normal or smaller text directly above or underneath the image with no spaces inbetween image and text. If no images are used then up to 4 consecutive lines of normal or smaller text is permitted. Do not pad out your text lines with blanks lines. A line of text is defined as having a maximum length of 400 pixels. If you want to turn the signature off in the future, you can come back and edit your post. If you have specified a signature in your profile, the box will be automatically ticked for you.
The forum Dons/Admins reserve the right to judge individual signatures, particularly those deemed to contain material of an adult or offensive nature. If the Dons/Admins think the signature is unsuitable for a family orientated forum, then it will be removed. If the user then replaces it without making changes, they will be suspended.
If you were replacing SB would it be better value to get another SB or an IB??
when will ivy bridge cpu's be available to buy and are they going to be worth getting over a 2700k?
They are reportedly to hit retail channels at the end of this month. As for benefits over a 2700k, the main performance increase with IB is the GPU, there are of course enhancements and refinements that make IB slightly faster clock for clock, but there is very little in it. The only other benefit to IB is slightly lower power draw/greater efficiency.
The most important feature is full PCI-E 3 support.
..with higher CPU temps may I add
Does IB and Z77 bring 16x/16x PCIe slots to the table? Or are you still limited to 16x/8x? That would be a bigger improvement than PCIe 3.0 IMO.
Are they that much higher though? I was under the impression that the process shrink and voltage drop would lead to lower temps?
