Best mid price ranged SLI cards?
8 Jan 2012
So I was wondering what the best SLI cards are with a price range of £200-300. Could possibly go £400-500. But anyway what IS best performance wise in those two price ranges?
31 Mar 2012
I mean a combined price in the range I said. And I thought SLI can out perform some single cards..?
2 x GTX 560 Tis may be about right for that price range. Easily overclocked. Very good performance in SLI and yes 2-way SLI (or more) will outperform a single card of the same type but this largely depends on the games you play.
OP
8 Jan 2012
Oh I see. Well Im still figuring out exactly what Im putting into my next rig.. So far Im only certain of the case, CPU cooler and RAM. Since Im waiting on the Ivy Bridge processor release to decide upon the motherboard and processor obviously. But thanks I guess Ill just go with a 680 instead of messing with SLI then.
3 Jul 2011
Essex
2x 560 ti
will give you more performance then a 580 or a 680
but you could always buy a 680 and then get another one later on down the road
1 thing though since i went sli my cards get a lot more hotter etc and you will need sufficiant cooling
OP
8 Jan 2012
Yeah.. I think Ill do the 680 road see what my cooling is like that way. Going for a CM Storm Trooper and Im going to try to make it keep as cool as possible.
9 Oct 2009
United Kingdom
I would personally go with a single card setup. Yes, SLI/Xfire offer great performance but as people have eluded to above it can sometimes be problematic. If your not aware, there will be some nice price drops on the high end AMD cards very soon, probably this weekend. I would personally go with a 7950 (should be around £300) if you game at 1080 or 1200. In a year or two, pick up a second one and go Crossfire.
28 Feb 2012
Chertsey
Personally I don't know what all this 'SLI is problematic' thing is all about. I've SLI two GTX580s back in Feb and have had ZERO problems (and i've never SLI or Xfire anything in my life, I was a complete noob just wanting to see what the fuss is all about).
Fitting and installing them was as easy as fitting and install anything else you have in your case.
Both cards were picked up fine first time, NVIDIA driver found both cards first time, no error messages, no HEAT problems at all while playing BF3 on full Ultra preset (bout 70c top card 62c bottom, 55% fan speed, V-Sync on), even overclocked both of them no sweat, and EVERY game I have thrown at it have worked first time (and they run QUICK)
I can't comment on xfire as i've never done it, bit I say SLI FTW, if you want to go SLI then I highly recommend it (just make sure you have a case with good air flow)
2 Feb 2010
East Midlands
Maybe you haven't had problems, but people have. Also, an SLI setup will be more effective on some games than others. In fact, SLI doesn't even work on some games. Far better off with a top end single card that will perform well across the board. No point in SLI mid range cards at all.
Given a choice of 2x 560's or 1x 680, I know which I'd choose. Two mid range old tech cards? Or a state of the art cutting edge card? No brainer really.
You may get the odd game that will perform better with the 560's but overall the 680 will win out with more consistent performance, less power usage, less heat, less noise, and more features. And if you really want to, you always have the option of adding another one later.
28 Feb 2012
Chertsey
well im not saying that problems won't occur, of course they can. But at the moment this thread is suggesting that you will ONLY have problems with SLI, im saying that chances are you won't and it's worth going for it.
And again I know SLI doesn't work on some games, NVIDIA website lists all games that support SLI so maybe check there first.
If OP wants to SLI mid-range cards then my 2 pence worth is to do it.
OP
8 Jan 2012
Yeah I see your point actually. Hadn't really thought it through but that was pretty much the point of the original post so I could decide upon what to get :)
2 Feb 2010
East Midlands
You didn't really read my post and comprehend it at all did you :p
