Hi All,
Just set up and filled my loop which is:
Res>pump>radiator>cpu>radiator>gpu>gpu
My issue is that my EK 4.0 pump/res combo seems to be making what i can only describe as a constant hard drive activity kind of noise which isn't terribly loud (no louder than the case fans) but its just the pitch of the noise which is annoying. I have bled the big air pockets out the loop by rocking and tiping the case around and I'm only left with micro bubbles flowing round the loop. The pump is sat on a thick piece of acoustic foam so vibrations aren't the cause.
The only issue I may have is that the pump ran partially dry while filling the loop for around 3-4 seconds 2-3 times (there seemed to be a delay between turning the power supply off and the pump turning off with my hot wired corsair AX1200 which cause the pumped to run partially dry when filling). Could this have damaged the pump at all and is what could be causing this noise? It's having no trouble pushing water around the loop so its not like its dead or on its last legs.
Should I wait a full 24 hours and see if the noise goes? Anyone have any ideas?
