Cheers mate. I think it'd be good if everyone posted some benchmark results running at 1200MHz and above as this seems to be easily achievable on any 7850, and it would really show what this card at it's full potential is capable of. I'd get the ball rolling, but I haven't ordered mine yet.
There's already loads of benchmarks in this thread and in the earlier 7800 thread.
http://forums.overclockers.co.uk/showthread.php?t=18384791&page=9
onwards.
I wouldn't say 1200MHz is a guarantee however. It seems pretty much all cards will do around 1150 at varying voltages without much problem (33% OC), going past that is luck of the draw. We've seen cards that'll go all the way up to the high 1200's, and other cards that refuse to budge from 1150.
As with all OC'ing its a gamble, but you can safely assume you'll get around 1150 with a fairly high level of confidence.
I would say however that the Sapphire and MSI cards do have far superior cooling to the VTX one, and as such if your card does require high volts to OC those would be the safer bet.
