I'm in the middle of building a computer and have all my parts besides the CPU, which I'm now carefully considering.
Since this is a gaming PC and I do not use many productivity apps, I will not really benefit from HyperThreading, so an i7 is a waste for me, and I will be going with an i5.
The choice is now narrowed down to an i5 3570k or i5 2500k.
From what I hear, the i5 3750k won't be that much more expensive, maybe £10-15 or so. However, if the 3750 does not come out within 10 days, I will not be able to use my 10% off voucher. So it could be £30-35 more expensive.
I will almost certainly buy an i5 3570k if it comes out within the next 10 days, how likely is it that it will come out within 10 days?
If it does not come out within the next 10 days, and I end up needing £30 more for it. Is it worth it? From what I hear, I will be paying the extra £30 for: lower power consumption, better iGPU and better performance per clock but a possibly lower max overclock which makes it difficult to gauge which would be better when I finish OC'ing them.
Is there anything I am missing or are the above 3 factors the only benefits I will see from IB? FYI I won't be using QuickSync, which is improved, so it's not really a benefit to me.
EDIT: Say the IB can't overclock as far as SB. Will a 4.4 Ghz i5 IB be less likely to bottleneck me than a 4.7 Ghz i5 SB in the future, when I upgrade to 680 SLI or other high end GPU setups? Or are they really the same in terms of which will last the longest without bottlenecking future GPUs.
