Road Cycling Essentials
Status
Not open for further replies.
Had a bad'ish dream...
My bike got stolen...found it bit later, but found only frame...been laughing that the most expensive bit, carbon frame was left behind...
on your road bikes, are your gear cables exposed or in coating(running under frame) ?
and what cables are you using ? need to change mine.
and a 'accident' today...once again chain came off..this time went over outside of crank, and scratched all over it :/
New tyres have arrived :)
any chance of posting some photos of the tyre from closer distance ?
and let us know what you think about them after first ride ?
This might interest Asprilla,
Just had a email from Paul and although he didn't save and screen shoots from the SPinscan software he does have my read outs from the final fitted spin:
Spinscan Average was 81%
Left Power Contribution 50%
Right Power Contribution 50%
L Torque Angle 90 degrees
R Torque 95 degrees.
I dont know what the other reading mean, but that one seems quite impressive :)
Certainly sounds good, perfectly even split in power leg to leg.
All ready for Sunday now, stuck a new tyre on the back as my other has some cuts and marks from training. Need a rear brake tweak as its developed a slight squeal since I did 60kmph+ coming down Mount Panorama and braking.
Depends on the bike. The cables will have an outer on either part of the inner or all. Shimano or Jagwire are cheap enough and do the job. Make sure that you lube the cables and make sure that they don't hit the floor or pick up any dirt whilst fitting them. Blob of grease on end of outers at the point you put the inners through is a good idea too.
Check limit screws on your mechs. Also check chain for excessive slack.
To be honest, I'm not 100% sure what they mean, just that thay were good!
Just googled it :p
Torque angle shows the angle at which each leg produces max torque.
Spinscan shows average torque as a percentage of maximum torque. Higher numbers are better. 100% would mean that you pedal in a perfect circle with constant torque through all angles. So 81% sounds pretty good to me as well.
Is £195 for bike fitting including shoes reasonable price?
Without shoes they charge £130...
Maybe anyone here knows a place in London where I could have fitting done?
Thanks
Got on the drops again, felt much nicer, still not got the "balls" to get on them during a fast downhill run but will start small and move up to it.
Really? I find the drops the most comfortable place on fast downhills because you get most leverage on the brakes.
Status
