The negative feedback says failed to mention item was an imitation. So I'd go for yes.
I'm sorry, but that cable is fugly!![]()
its just cable tidy ,one thing i dont like is the two thin wires as they get nasty kinks that may end up maybe damaging the wiresPanasonic RP-HTF600. Sound better than beats, my mate went from beats to them on my recommendation and never looked back![]()
Panasonic RP HTF600E-S
Any difference with the S?
Any thoughts on
Roccat Kave 5.1 Surround Sound Headset
i may be wrong, but i think the E just mans European, so they are the same
I also have the same Pannys as Shayper, well happy with them![]()
The only downside I found was the burn-in time, however it was well worth it
It would made you look like you have sideburn dreadlocksI'm sorry, but that cable is fugly!![]()
Any thoughts on
There are better headphones and there are worse headphones, but for an equivalent amount of money you can most definitely get better headphones.Are these actually decent, or just really over rated headphones?
The Kaves are great for gaming and movies. For music though, even the Beats are miles ahead of the Kaves. If your main purpose is music, do not get the Kaves.Any thoughts on
Cheers for the advice.
Still on the hunt.
Been advised to get HD25 by Senheisser. Still looking at the Panasonic too
Just get a pair of Sennheiser HD25-1 II and have done with it for at least a decade.
