- 26 Dec 2009
- North
Bit of a dilema deciding between these two bundles! Got a good price for my P67 SB setup and looking to upgrade/sidegrade to one of the following setups. Which one would you go for and why?
X79 System
http://www.overclockers.co.uk/showproduct.php?prodid=CP-391-IN - £229.99
http://www.overclockers.co.uk/showproduct.php?prodid=MB-057-AK&groupid=701&catid=5&subcat=2174 - £167.99
http://www.overclockers.co.uk/showproduct.php?prodid=MY-310-CS - £89.99
Total - £487.99
or
Z77 System
i7 3770K - £270ish ?
http://www.overclockers.co.uk/showproduct.php?prodid=MB-062-AK&groupid=701&catid=5&subcat=2261 - 169.99
Total - £530
Will be under water if that makes any difference paired with a GTX 680. Im leaning toward the X79 ATM as is cheaper + at least my WC setup will be put to use. Hoping to keep system for a few years so want to be future proof as possible.
Usage - Gaming, Light photoshop and lightroom ( i mean light)
X79 System
Total - £487.99
or
Z77 System
Total - £530
